About that proportioning valve, what I mean is the NLSV (nissan load sensing valve), on the frame rail of, what I thought was all D21's. You sound like you know what is going on, I just wanted to get that out there.
RT22 wrote: sticking or messed up caliper
When you instaled the new calipers, did you use the old guide pins? These little guys are problematic if they aren't serviced thoroughly and frequently.
By thorough I mean: cleaning the pins with a wire wheel or wire brush; cleaning the guide bores in a similar fashion with something that will fit in there; and having intact dust boots. I use only synthetic caliper lube on them (costs only a few bucks), it seems to hold its ground longer than axle grease. -SeanG-
