Truck bed
kibatheloanwolf
Car: 1987 D21 2.4L with a 5 speed manual trans
2010 Camry 2.5L with a 6 speed maunal trans
What is the Easy way to take the bed off of a hard body? And how easy is it to get back on?
RT22
Car: 1991 nissan hardbody
Basic bolts and remove lights and wiring and the gas filler neck. It is a pick up and lay on blocks deal with 4 guys or use a frame or something and use tie down straps and a come a long or jack system of some kind. Not hard just double check all mounting points before snatching the bed.
97PickUp
Car: 1997 Nissan Hardbody
RT is correct. Six bolts is all it is - if its clear of rust they'll come right out. I recently replaced the bed on my D21. The front two parts are the hardest to get to - so if you have a long enough extension you should be set. It only took two of us to left it, maybe a third just in case. The bed isn't self is going to weigh a good 200-300lb. Don't forget to unplug taillights. There is a large plug close to the end of the actual frame before the bumper mounts - this will disconnect all electrics from the bed. Also, there are three phillipshead screws holding the gas filler neck to the bed.
As for putting it back on - it's pretty simple as long as you line up the bolt with the holes. Here are some pictures:
Bolts:
Holes:
Hope I could help! Good luck
kibatheloanwolf
Thanks man had to do some rewiring under the bed...You live in cary? You know where four oaks is?
97PickUp
kibatheloanwolf wrote:Thanks man had to do some rewiring under the bed...You live in cary? You know where four oaks is?
Yes I live in Cary, NC. Four Oaks is about 45 minutes away. What wiring did you have to redo? My truck is throwing an engine code and I think it has to do with the purge tank under the bed.
kibatheloanwolf
The last owner did a s***ty job on trailer light wiring which was shorting on the bed also i had to scrub my tank out *Got some bad fuel* Are you ever in the Newton grove area?
Modified by kibatheloanwolf at 6:55 PM 7/30/2009
97PickUp
kibatheloanwolf wrote:The last owner did a s***ty job on trailer light wiring which was shorting on the bed also i had to scrub my tank out *Got some bad fuel* Are you ever in the Newton grove area?
Sounds like a fun job! And nopeeee, never been out there. Never heard of it to be honest.
kibatheloanwolf
ehehehe your definition of fun is waaayy diffrent from mine lol and yeah we are little heard of out here do you have an AIM messenger account?
97PickUp
kibatheloanwolf wrote:ehehehe your definition of fun is waaayy diffrent from mine lol and yeah we are little heard of out here do you have an AIM messenger account?
hahah.and i do but i haven't been on in ages - best contact would probably be via email ([email protected])
volvo850
Car: Nissan D21 4wheel drive 1990
I found a 97 std bed in great shape to go on my 90 D21. I broke one of the bolts up near the cab and wondered if this bolt is a separate piece of hardware from the bed or part of it. Have to go back to remove the two rearmost nuts and she'll be free and clear. Mike/colorado
