The00Dustin »
https://forums.nicoclub.com/the00dustin-u137235.html
Mon Jun 23, 2014 3:51 am
When you refuel, do you tighten your gas cap until it clicks? If so, you should still check and make sure you did at your last fill-up. If it tightens at all before it clicks, or if you have never been one to tighten it until it clicks, the first thing you should do is tighten your gas cap until it clicks and then have autozone reset the light again. Then, if it comes back on with the gas cap fully tightened for the duration of this tank and all future tanks, you can start worrying about what is actually bad.
