Troubleshooting in Savannah, GA
Including AR, LA, MS, AL, FL, GA, SC, and NC
smitty4130
Car: 95' S14 w/RB20DET, 03' BMW 330Ci
I'm in desprete need of some help. My current project is a 95' 240sx with a RB20DET swap thats been built from the ground up. I can not get the thing started. Its got the right timing, its got the right fuel and spark, and still nothing. Turns over fine. It just won't fire . I've replaced the MAF, Cam Angle sensor and Ignitor. Wiring swap was done by Carl H.
Anyways i'm looking for someone with some experiance with RB or SR swap's to swing by and put a second set of eye's on it. This is my first RB Swap and i'm really at a loss with where to go and what to do next. I've run through every single step in the RB Manufacture's Tech Book.
Email Me at [email protected] if you think you can help. Thanks!
KromCube
Car: 2009 Nissan Cube Krom
You should maybe try the Silvia/240 forum. They'll give you some better info. as that part is dedicated to your car. Hope you get her runnin' soon!
Return to “Southeast Region”
