robbie2883 »
https://forums.nicoclub.com/robbie2883-u41470.html
Tue Feb 02, 2010 5:59 pm
so i've tried all i can. not sure what i've done wrong but hoping you guys can shed some light. From what i've read on the rb25det you want to set base idle to somewhere around 650 rpm's. i have tried everything and cannot get my idle below 1000-1100. aac screw is turned all the way down (clockwise), tps unhooked and throttle pulley scrw backed all the way out. no vac leaks so i'm at a loss! i am running a pfc and can't put the stock ecu back in b/c of larger injectors.
thanks for any help
