Troubleshooting for a 2000 Pathfinder SE
ahendricks
Car: 2000 Nissan Pathfinder SE
My pathfinder has been running fine for several years; however, after letting it sit idle for the past month, it no longer starts, turns over, and none of the accessories turn on. I have replaced the battery and it made no difference. I'm thinking maybe the battery main fuse, but I can't seem to find it in the fuse box. There is a screw coming out, but I can't locate the fuse in there. Any help? Thanks!
WDRacing
When troubleshooting fuses, I usually pull them all and check them just to be sure.
Just so I understand, you're getting NO power to anything? Sorry I can't be of more help, I'm not a Pathfinder guy, just troubleshooting like I would on one of my other cars.
Welcome to Nico! We'll get this sorted out.
WD
ahendricks
There is absolutely NO power to anything. Its a new battery, so my thought was it had to be a fuse, right? I'm just not sure which is the fuse to pull and check. The fuse box labels the "battery main" but I can't find an actual fuse in that spot. There is another fuse coming off the positive terminal wire from the battery.
Aaron
00pathyse
2007 Nissan Altima 3.5 SE Sedan
Hopefully not mice
