ASIAMC,asiamc wrote:did you get the code fixed. I have the same code. If you fixed it yourself let me know how. I refuse to go to a mechanic. I also had code p0443, purge valve. I learned and fixed that myself, but I can't get rid of this last code p0446. email me [email protected]
Jude240,To fix the P0443, I just bought a new purge cut valve from nissan. Part# 14931-72F01, loc: B39 380 104. It was $84 with tax (might have to order it). It is very easy to replace. Just unclamp the three hoses coming off of the purge valve and put the new one on. Took 5 min.P04460, is the vent control valve or called drain cut valve. Part# 14935-54U06. It's in the rear, under the car, near the fuel tank/line on the passenger side. It is connected to the black canister and has two 10mm bolts holding it on, one electrical connect, and 2 or 3 hoses. Take that off and replace it. It's $72 at nissan (should be in stock). Don't forget to reset your codes, so that your light will go off. My problem is that the 10mm bolts appear to be stripped, so now I gotta spend $141 on a new black canister. Let me know how yours turns out. Or any other problems. I have a 96 240, you? Asia.jude240 wrote:
ASIAMC,
how did u fix the P0443 code problem? I need info on how u did it. I have the same error code on mine.
very common. i prob do one vent control valve every month and half of them need a canister too because the bolts rust.asiamc wrote:
thanks for the info, appreciate it. I have 97 240, again thanks I'll let u know what happensasiamc wrote:
