Cliffy15 »
https://forums.nicoclub.com/cliffy15-u10743.html
Wed Oct 22, 2003 2:44 pm
Hi guys!
I've been lurking around the boards for a few months (especially the faqs) trying to find some solutions to my car problems. I am not a car guy at all (computer programming nerd) so I am lacking in much of the basics but I'm trying to learn in a last ditch effort to avoid taking my car in for Nissan servicing.
I have a FSM, but much of it is a little too technical for me as I don't know where most of the intricate little parts (like sensors) are, nor what they look like. So I'm turning, here, for help.
Here's the car: 1990 Nissan 240SX (KA24E). Bone stock. 132K Miles.
Here are the problems: A few months ago, my car began having problems starting/idling. Part of the reason was leaky injectors which was making lose fuel pressure. I've since had the seals replaced and the fuel filter changed, but occassionally (I've noticed no other trend) I have problems starting the car cold.
The car cranks fine but sometimes takes awhile to "catch". The battery is good. The starter is new. The fuel pump is good. The plugs, wires, and distributor is new. New air filter.
When I do get the car started (have to basically start with the accelerator to the floor), I have to hold the throttle open, slightly, to make sure the RPMs don't drop and stall the car. Once I get to normal operating temp, things are quite a bit better although if I let go of the throttle, the RPMs drop rapidly and alarmingly low.
This leads me to the conclusion that my car is having problems at low throttle positions.
Additionally, when I open the throttle quickly, from idle, the engine drops RPMs, almost causing a stall, then catches up.
My solutions:Clean the Mass Airflow Sensor. (Did that, no problem)
Look for intake leaks. (Did that, one found and patched).
Reground the motor. (Looking into that, but my current ground is still good)
Replace TPS (kind of expensive, was hoping to have a better diagnosis before actually buying it)
Replace O2 Sensor (still waiting for a better diagnosis)
AIV removal (finally came into the forums and looked at that, today, will attempt within the next couple of days). Still, though, I did not have the indicative oily residue on my air filter.
My questions: I've been looking through the FAQ and haven't been able to try some of the solutions because either I don't know what part is being referred to, I don't know the location of the part, or I don't know what it looks like.
I have no idea what the following does, looks like, or where they are located. If someone could provide pictures and info, I'd really appreciate it:
BPR ValveEGR ValveAAV/AAC Valve (are these the same part?)AIV/IAV (are these the same part?)
Any help would be grealy appreciated! =)
Mahalo!
