EdBwoy wrote:The compressor clutch is engaged by an electromagnet circuit. The FSM might not go into detail on how to jump this, but I bet the connector that goes to the magnet can be fed power from the battery.
I can't remember if this is a single wire or 2-wire feed, so I'd recommend you check the FSM.
For the pressure sensor, I don't think that's a common failure point in Nissans, but outliers exist. Again, without going into the FSM, I believe it is a potentiometer (rather than discrete switch) and it reads progressive pressures from the refregirant. So right now it's reading zero (or baseline for the system) but if you jump/ ground it, it's going to go to max pressure and thus try to give you the most cooling... if you're still interested in investigating that.
Some obvious questions:
1. What is your ambient temperature and what's your set temp in the car?
2. Is the blower behaving normally in that it can still vary in speed?
3. What happens when you push "auto" inside the cabin?
4. What happens when you set the temp to either minimum or maximum?
It's pretty weird that the engine would idle higher even without the clutch engaging. I assumed the idle followed the increased load, not that it anticipated extra load. Gonna have to look into it sometime.
Thanks for responding!
To answer your questions:
The outside temp was around 70 yesterday, and a little colder today, and I set the car temp to 60, but played around with it as I was testing.
The blower works fine in max and min modes, and all the way through that cycle.
When you push auto, the blower lowers around 2-3 settings, decreasing the amount of air being blown into the car.
When I set it to max (coldest), it gets slightly cooler than warm, but not really cool. On Min (hottest), it will get hot like it should. No issues with it heating in both outside and recirculate.
As to the idle changing, it's definitely noticeable as if you were turning on/off the A/C. Would the fans draw enough to drop it?
