e_a_z_y wrote:
also tell me how to bleed rb20 is there a bleeder in it.
Modified by e_a_z_y at 10:18 AM 9/3/2008
Yes there is a bleeder on your engine. It's on the front part of the intake manifold. Here is a picture of it.
It's the part that has the red square around it.
Put your car so that the front end is up higher than the rest of the car, well at least that bleeder block.
It should be the bolt next to the yellow tag on the bleeder. Unscrew it and take out the bolt. Start your car and let it bleed itself out. Once you have coolant running out with no air bubbles, screw the bolt back in and you are bled out.
As for the turbo...does your cross pipe have a BOV/Recirc line like the one in my picture? A31/C33s didn't come stock with those. If not, the reason you are getting the ch s s s s s s is because of compressor surge. When at full boost, you let off the gas, there is nowhere for the excess pressure to go once the throttle body closes, so it goes back through the compressor.
If you do have a BOV/Recirc and it's an aftermarket BOV, maybe the spring tension is to tight and doesn't allow it to stay open all the way and it flutters.
The sound problem could be the intercooler leak or you have a leak somewhere else on your system between the turbo and the throttle body. Be sure to check all your hose clamp connections and also to check that your pipe connectors aren't cracked or split.
