Kiven422 »
https://forums.nicoclub.com/kiven422-u74246.html
Wed Jan 09, 2008 1:01 pm
Do you have an aftermarket stereo? Wires could be shorting out if they are not properly sealed off or taped up. That can cause a fuse/couple of fuses to blow. If fuses blow on bumps this could most likely be the problem. Your lucky the whole instrument panel didn't blow (happend on a friends 240SX).
Did you replace your brakes recently? If the brake sensors are bad or the brakes were replaced without sensors that WILL cause your tail lights and interior lights to go out but the brake lights will still work... replacing a fuse will not fix that. You must splice the brake sensor wires (they are only on the right side) so they loop to each other instead of going to the sensor. That will fix your tail lights after you fix that and mess around with a couple of fuses.
A bad fuse? Theres an "Ill" fuse on the drivers side that should be replaced and a "Tail Lamp" fuse inside the relay box under the hood next to the battery in a black box. The headlight fuses are also there. There are a few more fuses but I just don't remember.
Bad Bulbs? Its best to use OEM bulbs (as some people have car problems with non-OEM).
