Trouble with rebuilded engine
Istilldo
Car: 180sx
First of all sorry for my bad english.I have re-builded ca18det engine. new crank, piston, piston rod etc... the car is completely stock.There is no error given from ECU. Everything seems normal. I have done 1500mile running in.I have walbro 255lph fuel pump. and adjustable fuel regulator @ 2.4 bar at the moment.Everything at factory settings. But a have a problem, sometimes when I make full throttle from 2500rpm , car makes bap bap bap which I can call interruption at 4000-4500rpm. but not everytime.If I press gas pedal slowly from 3000rpm it goes to 7000rpm with no problem.
what can be my problem ? If you can help I would be very happy.thank u.
boost_boy
Istilldo wrote:First of all sorry for my bad english.I have re-builded ca18det engine. new crank, piston, piston rod etc... the car is completely stock.There is no error given from ECU. Everything seems normal. I have done 1500mile running in.I have walbro 255lph fuel pump. and adjustable fuel regulator @ 2.4 bar at the moment.Everything at factory settings. But a have a problem, sometimes when I make full throttle from 2500rpm , car makes bap bap bap which I can call interruption at 4000-4500rpm. but not everytime.If I press gas pedal slowly from 3000rpm it goes to 7000rpm with no problem.
Check for for leaks in your intercooler plumbing. Make sure you fuel pressure is not dropping off under load. I don't know what fuel pressure regulator you're using, but watch that as well. Since you're getting no codes on your ecu, pay close attention to the areas and components I mentioned earlier. Let us know how it goes and good luck.
Dee
float_6969
This also sounds like it could be an ignition problem. Often the ignition system will work fine until it's under load. Download the Factory Service Manual from the FAQ at the top of the forum. The procedure for testing the ignitor and coil packs is listed in there.
Good luck and keep up posted.
PS- Welcome to NICO!
Istilldo
Car: 180sx
thanks for your support guys.fuel pressure regulator is not dropping under pressure.today I hear a sound from EGI relay. Like beep. Can be interested with my problem?I download the service manuel. Reading it at the moment but its too long:)
Istilldo
Car: 180sx
today I made self diagnostic from ecu ecu give 3red4green detonation sensor circuit mistake
ca18det240hatch
common problem, but not the problem with your car. Hook that up tho...u gotta run a new wire from the knock sensor to the ecu.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
ca18det240hatch wrote:common problem, but not the problem with your car. Hook that up tho...u gotta run a new wire from the knock sensor to the ecu.
His location says Ankara which is in Turkey so I would imagine his isn't swapped.
Istilldo
Car: 180sx
we make the detonation sensor ok.no problem with ecu.I take of the EGI roley. no interruption now. works fine at the moment.
Istilldo
Car: 180sx
would be a problem without EGI roley ?
Istilldo
Car: 180sx
guys, I have the same problem again today. I need help.
