\PROJECTRB240SX wrote:OK WHAT ARE YOU USING TO MOUNT IT (STOCK X-MEMBER AND MOUNTS, MCKINNEYS, ETC.)? WHATS STUCK?
MY RECOMMENDATION (IF USING STOCK X-MEMBER AND MOUNTS):JACK THE CAR AS HIGH AS IT CAN GOREMOVE THE T/C ROD SUPPORT BRAKETSDROP THE ORIGINAL CROSSMEMBERSLIDE THE RB20 (W/ R32 X-MEMBER AND 240SX RACK ATTACHED) UNDER THE CAR INTO THE ENGINE BAYSLOWLY LOWER THE CAR ONTOP OF THE X-MEMBER AND JUST SLIGHTLY TO GET THE BOLT HOLES TO LINE UPLIFT THE ENGINE ASSEMBLY INTO PLACE AND BOLT INTO PLACE
THATS EXACTLY HOW WE DID IT.
Thx for the info McAdam, thing is i junked the Front clip not to long ago and i cant remember if i took off the mounts and front X-member from it. Is there anyway i can do the swap w/o those parts??McAdam wrote:ah, man! you need to get the R32 mounts! If you bought a RB20DET front clip, take the front crossmember out of the clip, it'll be a simple bolt in from there. Trust me, it took me 4 days of 6 hour days from removing the KA to test running the RB powered car. I put the motor/transmission in from the top. Just get a good engine crane and load leveler.
McAdam
...Because of a lil misunderstanding ive gone threw all this stress and sh*t lol. Thanks adam..It all makes sense to me now, BTW do u happen to know or can ya get me the R32 X member?;)McAdam wrote:The front crossmember is the thing that the eninge mounts are welded to. It is also the thing that your steering rack is bolted to, as well as the lower control arm thingys on your suspension. It is held to your car by 4 big *** bolts, 2 on each side. The R32 X member has the engine mounts in the location you need them in, which is about 6 inches forward of the sstock KA mounts.
McAdam
Damn 0ok, im not really willing to pay 500 bucks for mounts. And sadly the junk yard all ready trashed my clip.McAdam wrote:sorry man! When I did the swap we had the clip and we stripped it bare. You could try and call an engine importer and see if they have any spares laying around, or your other option is to buy a mount kit.
http://www.mckinneymotorsports.com/sale.php
they sell a kit, but its like A$550 or something.
If you can go to the scrap yard that you took your front clup to, I am sure tehy wouldn't want much for you to pull the front crossmember out!
good luck
McAdam
