trouble with programming
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
TIMGREEN2
Car: 2003 Altima S 2.5
So I have an 03' Altima 2.5 S. the car will not enter self program mode to program new key fobs. Has anybody had this problem? Any suggestions on how to fix it where to take it? Nissan dealership couldn't figure it out.
Reason: Moved to correct Forum
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
:welcome:
Moved your topic to the Altima Forum as the Audio Forum is pretty dead.
The dealership has a tool for programming keys. Did they offer an explanation as to why they couldn't get yours to work?
Are these keys the actual OEM ones that came with the car or replacements?
TIMGREEN2
At the dealership 3 different service techs including the service manager tried to get the car into program mode by inserting ignition key (not an original) into ignition 6-10 times without any success. The only suggestion was for me to take the car to an automotive electric specialty shop & have diagnosed. I asked if they could do that at their dealership & was told they couldnt do that kind of diagnosis. I've checked all the door switches/pins,everything is good.
Rogue One
2022 Honda Pilot SE
Unfortunately not all dealerships are equal. Before going to a specialty shop, I'd take the car to a different Nissan dealership to see if they can program the fobs. The Nissan dealership I worked for had a hand held device that paired the fobs with the car, rather than going through the key insert routine.
TIMGREEN2
Thanks,I guess thats what ill do .
outThere
Car: 2002 Nissan Sentra GXE
2004 Sentra
2006 Chevy Malibu
if the Nissan consult 2 or 3 is like the GM Tech2 there should be an option to program the keys. Right now i have a 2006 Malibu that i can not program the keys either using the car or the Tech2 i think it is the module that receives the signal forgot the name. will not unlock the car or lock either. for the Nissan might be the BCM I dot see a mention for a separate module.
TIMGREEN2
Thanks
Return to “3rd Generation Altima Sedan (2002-2006)”
