s15nc »
https://forums.nicoclub.com/s15nc-u7009.html
Sun Dec 19, 2004 12:06 pm
I have been having trouble with my starter motor so I took the car out for a test drive after installing a new starter and forgot to torque down the lugnuts on the passenger side front wheel (snugged but not tight). I drove around for a couple of blocks before taking a hard left turn and dropped the rear end out a little and when I went to correct I noticed that I had a problem turning the steering wheel, like I didn't have powersteering. So I got home and thought it was just the fact that I had not tighted down the wheel so I went ahead and tourqued the lugnuts down and the next time I went out for a drive I noticed that I had the same problem so I have been trying to figure out when else I will notice the problem and I notice it when I turn out and the turn hard back the other way, I only seem to notice the problem when I turn the steering wheel from having the wheels facing one direction going all the way to the other side and only for the turing after I get back to center. Now for a description of my car. I have Coilovers, nismo powerbrace, full swaybars, s15 lsd, and cusco traction rods. I also have a turbo kit on the motor and the only reason I mention that is because I dont know if the extra heat could be causing a problem. Now for the things that I have noticed different that could affect the car. It has just recently gotten cold, I also just recently put heat sheilding around my powersteering resivour and what I mentioned about driving with loose lugnuts, I also recently went on a little road trip with my car 1 1/2 each way which I have not done often since the turbo kit install. I dont have a clue what the problem could be. I am thinking it may be either heat related resulting in maybe the powersteering fluid having broken down. The other thought is that the power steering pump is maybe starting to go. I was just wondering if anyone has had somthing of the same kind of problem.
