Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Sun Mar 18, 2007 5:33 pm
This could be the indication of a failing fuel pump and/or faulty fuel pressure regulator.
If it is the fuel pump, it will sometimes be an intermittent problem, then it will eventually fail.
In regards to the fuel pressure regulator. It is supposed to hold the normal fuel pressure over a certain period of time. If it is faulty, it could be releasing all of the fuel pressure over night or even instantly. Then, when you go to start the vehicle, the fuel pump has to build that pressure back up before it can start.
Just two possible causes. But to diagnose both, you will need a fuel pressure gauge hooked up.
