trouble starting my car
kevin223
Car: s13 ka-t
:mad: :mad: i just reacently got my car started after a 4 week strugle putting my turbo on , took it out for a drive and the bov wasnt working so i checked for leaks all over and found the t hook for the silicone line was broken as i replaced that , turned the car on and reved it to about 6500 the rpms graduately went down and the car just turned off , i tried starting it again and it wouldent the only thing i get out of it is a slow cranking but no fiering . please help any idieas :confused: :confused: i checked all my relays , injectors , fuses and nothign i think it could be the starter died out or the alternator
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
If its slowly cranking, check your battery. Could be your alt did not charge it enough.
Battery charge works like so:
Full charge: Strong crank, spark and starts
Lower charge weak crank, spark and starts
Even Lower weak crank, no spark and doesnt start
Even Lower usually starter clicks
And empty: nothing...
What does your battery read in terms of volts? Charge it, and get a reading while the car is running to confirm alt is charging the battery.
kevin223
Car: s13 ka-t
their all fine voltage was reading at 12.4 , my concear might be a bent rod ,beacuse it was taking to a high rpm and later that day i found out one of my t hooks was broken so the wastegate did not open and it put mad pressure to it but in terms of electrical problems its good , good voltage , lights dont dim out , no rust spots ect
