trouble starting my car
kevin223
Car: s13 ka-t
:mad: :mad: i just reacently got my car started after a 4 week strugle putting my turbo on , took it out for a drive and the bov wasnt working so i checked for leaks all over and found the t hook for the silicone line was broken as i replaced that , turned the car on and reved it to about 6500 the rpms graduately went down and the car just turned off , i tried starting it again and it wouldent the only thing i get out of it is a slow cranking but no fiering . please help any idieas :confused: :confused: :confused: i checked all my relays , injectors , fuses and nothign i think it could be the starter died out or the alternator
ProudNissanFreak
Car: 2005 Imaginary WRX STi, 2003 Civic
Starter/alternator should be the first place to check. How's the battery? Any corrosion around the cables? Loose cables?
kevin223
Car: s13 ka-t
yes their all fine i checked for all sources related to electricity , this weekend im going to perform a compression test to check if any pistons are broken , rings or bent rods thats my theory for now untill i try it , i was talking to one of my budies and talk me bent rods usualy tend make the engine strugle to crank hopefully thats not the problem :ohno: but at the same time good for a rebuild
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
Out of gas???
