jmckeogh »
https://forums.nicoclub.com/jmckeogh-u229959.html
Thu Jun 26, 2014 6:26 pm
I have had an intermittent problem with starting my 2013 Rogue.
On four occasions I turned the key in the ignition and there was no response. It did not respond at all, as if there was no battery or the car was in gear. I played with it and discovered that if I moved the gear shift from Park to Low and back again a few times the car then started with no problems.
The dealer checked and could not find anything wrong. They reset three computers and that helped for three months but I had the problem again yesterday. They told me that the next time it happened I should call and have it towed to the dealership so they could check it when it was acting up. I won't bother because in the process of towing the driver will move the gear ship a few times and that will clear up the problem.
Does anyone have any suggestions?
