metalmulishiaS13 »
https://forums.nicoclub.com/metalmulishias13-u19277.html
Fri Jun 25, 2010 2:47 pm
Like the title states, I have been trying to figure out why my car doesn't like starting after being warmed up. It starts perfectly fine cold. After driving and warming the car up, If I turn the car off or stalled it; usually it does not like starting again. I have been able to bump start it when this happens. When I go to turn the key, everything powers up just fine. However the starter does not engage( but can be bump started). I have relocated my battery and have since re done the wiring thinking it was that. So I now have a cable directly from the battery to the starter and alternater as well as a power wire feeding my fusible link at the front of the car where the battery would normally sit. Now I am wondering, does this sound more like I am in need of more engine grounds, or is this a replace starter and call it a day kind of a thing. Only reason I suspect the starter is because I can bump start it when it doesnt want to start and for a while a little bit of coolant was dripping on to the starter, till I fixed the leaks.
Any help would be appreciated.
metalmulishiaS13 on Fri Jun 25, 2010 9:47 pm, edited 1 time in total.
