coolhand »
https://forums.nicoclub.com/coolhand-u34947.html
Mon May 08, 2006 5:09 am
Here is some information on trouble spots on maximas and I30's
from this linkhttp://auto.consumerguide.com/Auto/used/
1995-99 Nissan Maxima: ReliabilityTrouble SpotsConsumer Guide's® Auto Editors have scoured repair bulletins and questioned mechanics to search for commonly occurring problems for a particular vehicle. In some cases we also give possible manufacturer-suggested solutions. In many instances these trouble spots are Technical Service Bulletins posted by the manufacturer, however, we have our own expert looking at additional vehicle problems.
Automatic transmission: The original automatic-transmission (model F04) shift solenoids allowed slipping and premature wear. (1997)Brake noise: Rear brakes rattle on rough road. (1995)
Brake noise: Groaning from the rear brakes is caused by the parking brakes not fully releasing, requiring new brake cables and pads. (1995-99)
Brake noise: Groaning from rear brakes at slow speeds may be due to binding parking brake cable. 1995-99)
Clutch: The clutch may slip when accelerating hard in 4th or 5th gear due to a problem with the friction material. (1995)
Engine knock: Spark knock or ping may result from a defective onboard computer. (1995-97)
Engine noise: Noise from the front of the engine may be caused by excessive play in the timing chain for which a new tensioner and chain guide are required. (1995-96)
Hard starting: Hard starting, stalling, or stumbling under load could be caused by corrosion of the coolant sensor. (1995-96)
Hard starting: If the engine does not start on the first attempt, the engine may crank very slowly on the second attempt because of a problem with the engine-control computer. (1995)
Rough idle: Several problems (no-start, no A/C, rough running, etc.) can be traced to broken wires in the engine compartment where the harness bends near the right strut tower. (1995-97)
Rough idle: Rough running engine accompanied by check engine light may require revised powertrain control module. (1997)
2000-03 Nissan Maxima: ReliabilityTrouble SpotsConsumer Guide's® Auto Editors have scoured repair bulletins and questioned mechanics to search for commonly occurring problems for a particular vehicle. In some cases we also give possible manufacturer-suggested solutions. In many instances these trouble spots are Technical Service Bulletins posted by the manufacturer, however, we have our own expert looking at additional vehicle problems.
Audio system: Popping and crackling noises in the audio system are often due to cell phones plugged into the cigarette lighter. Using a different power source or moving the phone often helps. (2000)
Cold-starting problems: The engine may idle too slowly or stall when first started (below 40 degrees F). Reprogramming of the powertrain-control module is required. (2000)
Engine misfire: Bad mass airflow sensor can cause lack of power, acceleration. New MAF and reprogramming computer should fix the problem. (2000)
Sunroof/moonroof: The headliner may sag near the sunroof because the Velcro does not hold sufficiently. Additional clips were being installed under warranty. (2000)
Vehicle noise: Noises from the right front strut require replacement of the rubber spring seat. (2000)
2000-04 Infiniti I30/I35: ReliabilityTrouble SpotsConsumer Guide's® Auto Editors have scoured repair bulletins and questioned mechanics to search for commonly occurring problems for a particular vehicle. In some cases we also give possible manufacturer-suggested solutions. In many instances these trouble spots are Technical Service Bulletins posted by the manufacturer, however, we have our own expert looking at additional vehicle problems.
Headlights: The headlights may quit working because of a problem with the connector plug. (2002)
Rough idle: The engine may lack power or run rough or surge due to the mass airflow sensor failing. (2002-03)
Sunroof/moonroof: The sunroof may have problems including opening spontaneously and trouble setting the switch to the proper position or cold weather damage. (2002)
1996-99 Infiniti I30: ReliabilityTrouble SpotsConsumer Guide's® Auto Editors have scoured repair bulletins and questioned mechanics to search for commonly occurring problems for a particular vehicle. In some cases we also give possible manufacturer-suggested solutions. In many instances these trouble spots are Technical Service Bulletins posted by the manufacturer, however, we have our own expert looking at additional vehicle problems.
Brake noise: The rear brakes may moan or hum when released below 5 mph requiring replacement parking-brake cables and brake-pad retainers. (1996-99)
Dashboard lights: Some cars with the California emissions package may ingest water into the evaporative emissions canister, which triggers the check engine light. (1996)
Engine fan noise: The mounting flange for the fan (on the water pump) can come loose after service if the fan pulley is not installed properly during repairs. (1996-97)
Engine knock: Spark knock or ping may result from a defective onboard computer. (1996-97)
Trunk latch: The trunklid opens by itself from either the striker being out of adjustment or the driver accidentally hitting the release switch. The striker may be adjusted, and there is a revised switch to minimize accidental actuation. (1996-99)
