Trouble shooting the Hand/E-brake
JXN
Car: Nissan 240sx S13 hatch
Hi,
I've recently encountered a problem with my hand brake. It wont lock up. Im curious to know what might be wrong.
Background story:I do a lot of drifting because I host monthly drift events at the track. It never bothered me before because I wasnt that good at drifting. As my skills got better, I figured that the e-brake is CRUCIAL for drifting when you are at an advance level.
My attempts at troubleshooting:First thing I did was trying to tighten the cable in the cabin. It was loose, so simply tightened up a bit. If I remember correctly, to test the hand brake, you need to be going about 10-15 mph in a straight light, put the car in neutral and pull the hand brake, and it SHOULD lock the wheels.For me, it just slowed my car down slowly.
Next thing I did was change the rear pads and rotors. Tried again. Still didnt lock up my rear wheels.
In fact, the only time that my rear wheels lock up is when I'm already drifting and the rear wheels have no traction. Makes sense right?
Possible solutions?Im thinking the calipers by be bad. I checked the rear cables for slack. The cables seemed fine. Do you guys think its my cables? Is there a way to tighten the rear cables? Or do I need to replace them?
Any input or help is much appreciated.
Thank you!
ilovesideways
Car: 240SX S-13 KA24E
sounds like the e brake cable is stretching.
caspers_240
Car: 91 s13 fastback
I had the same problem... i went threw a "process of elimination" and spent a ****-ton of $$ before i found the problem... long story short, completely new braking system. If you run out of adjustment, get a new cable first. Also, check anchor points/guides under the rear sub frame.
uberkillerz240
Car: 1991 240sx sr20det redtop w/ bpu
Lol. I know its not related to cars, but i did this on my redline bike. Stretched the cable. It can happen to any cable. Check that out though.
S13Joe
Car: 92 Coupe
i would say stretched cable
snake240
Car: 92 hatch SR20DET
