alexanderfrazier »
https://forums.nicoclub.com/alexanderfrazier-u215893.html
Wed Feb 13, 2013 1:08 am
Ok first things first. I did as much research possible and still haven't found an answer.
I have a 1990 Nissan 300zx with auto transmission, everything stock.
The problem Im having is that when the car gets wet (rain, washing it), transmission will only shift at over 4500 rpms. Now onces it dries a couple days its back to normal, it shifts fine.
Ok, what I have done so far: I did a auto trans.diagnosis and the third light flashes longer which is the throttle position sensor.
After everything dries it no longer shows a problem with tps. So something is getting wet perhaps and throwing the tps off which obviously affects my shifting.
One last detail. There is a missing vent cover where the wipers are, the one that doesnt allow water to get in the engine bay righr near the battery is. So I have recently noticed that battery gets wet along with anything else in that space.g
Any ideas would be much appreciated!
