smitty4130 »
https://forums.nicoclub.com/smitty4130-u124200.html
Sat Jun 27, 2009 5:12 am
The Issue: Motor won't start after fresh rebuild. (Started once for about 10seconds and then died)The Backround: Purchesed a ECCS RB20DET to swap into my S14. First thing I did was carefully tear it down so i could rebuild. I Vated The torn down block and head. and rebuilt the block with new piston rings and oem pistons that i had ceramic coated. On the head I used all new components and seals. I also replaced all the common things such as water and oil pumps, all belts, and spark plugs. Using the manual I rebuilt the motor to near oem specs. I my intentions were to break the motor in, in oem form. Carl H did the harness conversion.Where i'm at: I've replaced the ignitor with the j30, I've tryed starting with maf connected and with out, i've tried reversing the starter and alt wires, I've test the cas several times and it pass's. I'm getting spark and i'm getting fuel but no combustion (except for the one time). I've also tried reading the light on the ecu but it stays solid red with out blinking and then turns off.
What I think: From all the other motors i've worked on given that its getting spark, fuel, and air i would say its a timing issue, however i installed the greddy timing belt in line with the dimples on the cams gears and crank gear and the lines on the belt. So if i did that how could the timing be off?
Also the red light on the ecu not blinking at all seems fishy to me, but if it started that one time how could the ecu be screwed?
Please help guys i've got to get this thing out of my garage. Thanks
