Trouble Shooting Code P0325 & P0440
shiaokaz
Car: 1997 Nissan 240sx
Hey All
I took my car to Autozone and received two of the troublecode
P0325 and P0440I have a Nissan 1997 240sx with a code of P0325, knock sensor bank 1 also P0440 Evaporate Emission Control System...I am not sure which on that engine is bank 1. Front or rear? Any tips on doing the job or where the sensor is located or how to solove the problem would be appreciated.thank you
shiaokaz
no one can help me out pls help
niznos
Car: 03 Z-track, 98 Maxima GXE, 90 240SX RIP
I know it's a bit late on this, being 2 months after the initial post, but I found this on a search, and thought I'd address it anyways, maybe it will help others in the future or if you have not fixed the problem.
P0325 knock sensor bank 1: well, since you have an inline 4 in the 240sx, it's the only bank there is, and thus it's bank 1, you will only have 1 knock sensor. Place the sensor and make sure to clean the ground on it too, follow the wire to where ever it is.
P0440 Evap system, small leak: Check all vacuum lines coming to and from the evap canister and make sure there isn't a rip or any air leaks, replace all bad lines. You may want to pull the solenoid and clean it out as well. Spray some run-of-the-mill carb cleaner in there, let it dry and reinstall.
Goodluck.
