Afrikaaner »
https://forums.nicoclub.com/afrikaaner-u143971.html
Sat Nov 05, 2011 4:45 pm
i have an NA with a z1 shortshifter on a manual transmission, brand new about 2 years ago from a dealership, i put in redline transmission fluid from day 1, was running pretty damn smooth until recently. i have a hard time getting in and sometimes staying in gear. the problem mostly presents itself when shifting from 1, 3, or 5 into 2 or 4 or from 2 or 4th to 3rd or 5th (basically any shift from a gear you push foward into to one you pull back into or vice versa). I did have an old shifter support bracket i replaced recently after this started presenting itself (the rubber had torn, but i was able to get a temporary fix on it until i replaced it).
i can't tell if the problem is with the transmission or the shifter or something else, but what happens is it doesn't feel like the shift knob goes all the way into the gear - it's as if i should push a full inch, and it only goes 3/4 of an inch, so the teeth are juuuuust meshing and i can use that gear or it starts to grind horribly and i try again. sometimes when i get it into gear and give it some gas, then stop giving it gas, it will pop out of gear. so i'm not really sure what could possibly be causing this. i try to avoid rev matching and such, and on such a young transmission, it's hard to imagine anything being wrong with it, but who knows. i know the transmission itself gets pretty darn warm after a bit of driving (either from close proximity to the cats or maybe just friction or both), not sure if this contributed to this problem. anyway, let me know you guys think. cheers!
