Holidazed wrote:Pwnin O'Brien: thanks for the info!
What does the shift lock solenoid sensor look like and where on the pedal arm should I be looking? do i need to take off the steering wheel/lower dash cover or can i see it by just sticking my head under the steering wheel/pedal area?
No you don't need to remove any trim panels to see it. You need to get on your back in the driver foot area and get as close to the brake pedal as possible, looking up so you can see the entire brake pedal lever. Looking up at it, there will be two sensors, the one closest to your head is for the cruise control and the further up sensor is the ECU brake sensor. Just visually inspect it while depressing the brake pedal with your hands. You will be able to see that the sensor is adjustable and it has a bunch of notches on it to adjust the location with respect to the brake pedal lever.
I doubt that this sensor adjustment is really your issue, but you never know, weirder things have happened.
stevebaz wrote:Look at your shifter.on the base of the shifter you will see a 1/4" square plastic plug on the top right side.Remove the plug and take a small shaft about 5" long.At the bottom of the hole is a small lever use the shaft to push down on it.While moving the shifter. This is the emergency release for the shifter. You must hold it down to shift.The shifter release solenoid is under the shifter cover where all the linkage is on the right side. I did not replace the solenoid. I did wire tie it up so it couldn't lock me out anymore.
That's another option. If you don't mind not having the shift release solenoid inactive (which I don't see any problems with since you need to depress the shifter button to shift out of park anyhow) then I would probably recommend this option if the solenoid is bad.
