Hey guys thanks for the replies! I ended up fixing it, in case anyone has this issue again heres a very simple fix:
There is a snap ring located in the compressor housing of the turbo, so that part that kept getting in the way can easily be rotated left or right if you use a good set of needle nose pliers to squeeze the snap ring and then simply rotate the turbo
