911/Q45 »
https://forums.nicoclub.com/911-q45-u148.html
Tue Dec 17, 2002 10:35 am
That sounds expensive, but I like your attitude of lemons to lemonade. You'll get lots of input besides mine, but I'll get things started. Eibach makes springs that lower the front about 1.5 inches and the rear about an inch. Tokico makes shocks that are stiffer than factory, the blue variety. Stillen makes adjustable upper control arms and tension rods that allow you to adjust caster and camber on the front. The lower springs make adjusting the suspension nearly mandatory and it doesn't hurt to shim the upper control arm mounts about 0.25" also to keep the camber in bounds. The factory front bar is about as good as it gets, some guys bush it in urethane, I think the factory rubber is fine. The rear sway bar comes in two sizes, 20mm from the HICAS cars, 24mm from the active ones. Both are an easy install, I have the HICAS bar. Get all the factory brackets and bushings, again some guys like urethane. There is a subframe around the rear differential that can be damaged in an incident like yours and like wise the mounts for it and the trans and engine. They are liquid filled and damaged ones can be the source of insidious vibration and handling quirks. Some problems along those lines don't show up for awhile, so save a hefty chunk of your budget for that stuff. I'll let everyone else fill in the gaps, good luck on your project!
