trouble idle
98camaroz
Car: 92 s13
anyone know what could cause a ka to have trouble keeping idle.. here is a vid
http://www.youtube.com/watch?v=rhp2ZWHBolwthings ive checked:fuel pumpfuel filtertpso2 sensorsold fuel
Airmanspecial
Car: 1990 240sx
has that motor been recently swapped in? if so...have you swapped your fuel send and return lines?...you said in your video you ddint know why you didnt have fuel pressure...andn that it cuts off after 12 sec....like you fuel is pressurizing youre fuel rail...then gettin block at you re fuel filter casue its goin the wrong way...your fuel pump is designe to run at a constant volum/pressure which is why you need a return line to keep that fluid moving.....swap thos 2 lines and see what happens...
98camaroz
Car: 92 s13
ya ive been working on it...damndest thing..now we got it running right but soon as i drop the ebrake it cuts off...imma check out some more **** with the vaccum lines maybe something will come up
Airmanspecial
Car: 1990 240sx
so swapping the lines worked?are you workin with an Automatic?
843posxe
Car: 1991 240sx xe
looks like vacumm hose is blown somewhere or hooked up in the wrong spot
98camaroz
Car: 92 s13
well ive switched some lines and checked more stuff around....only thing left to check is the fuel lines and check the pump...
and its a 5spd.. built ka swapped in
