Trouble fitting single DIN and universal pocket with stock trim plate
erick.s
Car: 2008 Altima 3.5SE Coupe
I picked up the stock double DIN dash plate from nissanparts2u and the Metra universal fit dash pocket to use with my Pioneer single DIN stereo. The Pioneer fits fine but the pocket doesn't fit. No matter which of the included frames I use on the pocket it's too wide. Those of you that have done this, what did you do to get everything to fit properly?
Calcvictim
Car: 2002 Maxima
post some pics, to give a better idea of what doesn't fit
maybe so dremel work will be required
Hephaestus
Car: 2006 Altima 3.5 SE
Erick,
I would consider going to http://www.crutchfield.com and picking up a single DIN adapter from them. I had a similar issue trying to install a single DIN head unit in the stock location and ended up buying from Crutchfield instead. The kit I purchased worked perfectly and even provided me with some extra storage area for things like my "smokes", garage door opener, lighter, and head unit remote. Best of all, it only cost $20. Here is the link:
http://www.crutchfield.com/S-O...=3121
Good luck,
erick.s
Interesting. Do you have a pic of that installed?
