traviS13 »
https://forums.nicoclub.com/travis13-u27744.html
Mon Apr 11, 2005 10:20 am
can i still read the trouble codes on my car if a japanese tuning shop upped my boost i think with a chip but there was something to do with the blow off valve can you tune boost with a blow off valve. did i just make any sense. if not let me know ill try to be more clear. thanks oh yeah and what type of oil should i be using someone told me that the lowest weight should be 15w40 cause my car has added boost so at max boost 15 or 18 psi or something. its a ca18det so factory boost is around 7 or 9psi i think. someone else said nissan recomends 5w30 for the sr20det so im not sure if the ca18det would be different but anyways i was told 15w40 cause at high boost the low viscosity oil is too thin and will blow by valve seals or something. does this make any sense or have i been had. more thanks
Modified by traviS13 at 2:06 PM 4/11/2005
