You have a 2001.5 Pathfinder.
Replace the passenger's side post-cat (downstream) oxygen sensor with
this Bosch direct-fit sensor from Advance Auto Parts. Bosch is the manufacturer for the OEM sensor. Order online and use discount code
VISA and pick-up in store to get the sensor for $53 before tax. You'll need a 22mm or 7/8" oxygen sensor socket for replacement. That should take care of the P0138 and P0139 codes. P0160 is the driver's side post-cat (downstream) sensor. Use
this sensor as a replacement - order as a separate order with the same coupon code the day after you buy the first one to get it for $50 before tax.
