95_GXE »
https://forums.nicoclub.com/95-gxe-u16247.html
Wed May 12, 2004 4:25 am
Well checked continuity for all of the 4 wires going to ECU. All good. Pulled distributor off, turend key on, and probed blue wire while turning cam sensor shaft. Geting the 5 volt spikes for every degree. Same result for yellow wire; 5 volts for every 180 degree. So far that is all of the tests that the book describes for testing the cam postition sensor. Still not starting, and the computer is not sending out the pulse for the injectors, nor spark. Still getting 0101 code. (Cam Postiton Sensor). Pretty stumped. Should I replace the cam sensor again just for kicks? It is under warranty. Is it possilbe that the ECU has somehow gone bad since the I put new timing chain in?Mucho help needed, and thanks again for the advice so far!!:ylsuper
