bitplayer »
https://forums.nicoclub.com/bitplayer-u16187.html
Sun May 09, 2004 11:36 am
I've got a 93 240sx with the ActiveSpeaker system. I've had the rear amp bypassed for years, with the stock speakers up front remaining silent out of laziness/disinterest. I have the headend fader set to 0% front/100% rear, so there should have been no power going to the front speakers/amps.
I've been driving the car a lot lately and I figured that I would bypass the fronts this weekend.
I pulled the doors apart and pulled the amps out of the speaker enclosures. I mounted some new 4x6 JBLs in the enclosures. I cut the old gang connector off of the wiring harness and connected some wires:Left Side:blue with white stripe blue with yellow stripe
Right side:brown with while stripebrown with no stripe.
The other three wires (on both sides) were unused.
After hooking everything up, I powered up my headend only to watch it display it's clock for a while and then power down. No rear speakers, no power antenna noise, nothing. I didn't even have a chance to change the fader front/rear balance.
I have a Blaupunkt headend from the late nineties. It's plugged into the Nissan harness with a adapter from Crutchfield.
I'm using the existing Nissan wiring harness because I can't see any simple way to get better speaker wire (which I actually possess) through the door and into the passenger compartment without a major hassle. I know that I can't push as much current through the wiring harness, but I'm only pushing a max of around 25 watts a corner.
I'm not after a sweetasskickin' system, I just want to listen to NPR and my iPod.
Thanks in advance,
