DS13 wrote:could you possibly post a couple pictures just so i can make sure that i do it right
Here I stole them off of ebay, haha. Duals baby Like I said this harness for low/high is plug and play on S13, you have to make your own wiring for fog lights. And if you dont have that JDM S13 bulb harness, I'm sure you can make your own harness, bulbs just have blade type terminals nothing fancy.
There is a plug by the battery, look in there , it has a dummy plug over it, that is for your fogs. You will also need to install a fuse, and relay in engine bay IIRC. and if you have JDM fog switch, there is a plug inside car behind dash/gauge bezel.
If you do your fogs this way they only work with low beams, most people change that so fogs are independent of all lights.
But use the oem fog harness, so you wont have to mess with running wires and ****.
