triple gauges
Nissan 350z / Nissan 370z general community discussion forum
jem
Car: 2004 350z base model w/manual trans
Hello,can someone please help me figure out this ongoing problem with the triple gauges on a 2004 350z?They stop working before and then worked again for awhile,now not working.I was thinking a loose connection.I am not sure what to remove to look or how to trouble shoot for this.thanks
Reason: Moved to correct forum
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
Intermittent failure is most likely a bad connector or ground somewhere. Let me ask this, has the stereo been out lately?
jem
The stereo was never remove,however the center console was removed 5yrs ago when i had a new carpet installed.Do you know the wiring for those gauges and how to check connectivity?thanks for your response.
djwarner
Car: 1971 240Z Series I
2006 350Z
There is a connector under the center console that must be disconnected to remove the console. It obviously was not fully connected when the console was re-installed.
evildky
06 Nissan 350Z GT
Just gotta dig in and see what you can find. Start by pulling the triple cluster and checking the harness at the rear then follow the wires.
BusyBadger
Car: '92 Nissan 240SX
'05 Nissan 350Z
'13 Nissan Juke
Yep, those gauges either work or they don't. Definitely sounds like a loose connection.
Return to “350z / 370z Discussion”
