Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Fri Aug 23, 2002 4:10 pm
No real shortcuts here... you have to remove the trim around the shifter, the ash trey/radio/climate control trim, the steering column cover, and the trim around the instrument cluster. Be careful removing the instrument cluster surround - it's easy to rip and scar it on the lock release mechanism on the ignition switch. Then you remove the four screws holding the cluster in and you're there. Make sure the bulbs lock in good when you put them in... had one fall out about three months after I replaced it the first time...
If you need more detailed dash removal instructions and you don't have a manual, let me know and I'll try to type in something...
Heath
