trim work
GCIA4LIFE
Car: '93 240SX
I am doing some body work on my car and want to pull this trim off without wrecking it so i can reuse it. Can anybody help?
Hi GC, welcome aboard!
I've not seen that removed without damage, but I'll try to get some bodyshop guys in here to answer your question.
I'm sure it can be done successfully.
kamikazeee
Car: 1991 240sx
I just pulled out the insulation gasket thingy (I think there is some screws on it) and there are screws on that trim to pull it off.There shouldn't be any demage, unless u rush
GCIA4LIFE
Car: '93 240SX
thanx for helpi'll try that later and see what happensone more questionis it easy to reinstall?
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
I think the FSM shows either screw or snaps holding the trim....maybe you need to take a look at the section showing that .....it should be an FSM you can download in the FAQ's forum......I looked into that one time I was going to repaint mine.....
kamikazeee
Car: 1991 240sx
Yeah it's pretty easy to reinstall, except the gasket insulation thingy, bit tricky but you'll get it, plus If You have it off it's nice to sand it and put a coat of gloss black on it, but thats only me cuz I had a lot of dings and nicks in it
GCIA4LIFE
Car: '93 240SX
Alright I just got the trim off.First you pull out the weatherstrip stuff, which is wedged in. I just carefully pryed one side out and it popped out. There is some snaps on either end which come out. Unscrew the trim and thats it. Pretty easy
