Trim Levels
Quaraxkad
I'm looking to buy a Q45, either first or second generation. I've found some Q45t's for sale, but when I look up the VIN numbers they always show the trim level as "A/Base". I've never seen one listed as Touring, is Touring not actually a full trim level but just an options package? In any case, besides the trunk lid, what are some obvious indicators to look for to confirm that a Q45 is indeed a Touring edition?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
I'm sure you've already read the basics on Wikipedia.
Infiniti Q45 wiki
For more in depth info on a particular model year you can head over to Infiniti News to check out the press releases.
Example:
2002 INFINITI Q45 Press Kit
Quaraxkad
I have indeed read the Wikipedia article, and it suggests that Touring *is* a full trim level, at least for the first generation. If that's accurate, it isn't reflected by any of the VIN numbers I have looked up.
And unfortunately that Infiniti News website makes no mention of Q45 prior to the year 2000, so it's no help for first OR second generations.
Rogue One
2022 Honda Pilot SE
Quaraxkad wrote:
Fri Feb 03, 2023 8:11 pm
The Infiniti website is a little clunky, even if you're using a proper PC. The site does go back before 2000, but only to 1997.
1997 INFINITI Q45 Press Kit
1998 INFINITI Q45 Press Kit
1999 INFINITI Q45 Press Kit
Q451990
Although Infiniti may have (or used to have) a database to know what trim level matches a VIN, I don't think there's anything specifically in the VIN that indicates trim levels or option packages.
https://www.infinitihelp.com/diy/common ... ti_vin.php
Maybe looking up the VIN on the parts site would tell you more information based on the parts it says are a match?
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
Where you see them for sale. I think I found one or 2 for sale in the entire country right now
