Trim colors
ErMasta
The rogue's inside trims come in two colors right?
Gray and beige ?
For example: Visors
Thank you
philipa_240sx
Well sort of...
The top half of the interior is the same beige color on all Rogue's. I have verified this as all the upper interior trim pieces including the visors are only available in one color. The difference is the lower half. If you select black cloth, then you get black lower door panels and carpeting. If you select the grey cloth, you get grey lower door panels and carpeting.
Look carefully at the last image below, notice the beige top and grey lower panels in the hatch area. The same beige continues through the headliner, A & B pillars and visors.
Black Interior:
Grey Interior:
ErMasta
You are the best !!
Thank you :dblthumb:
I just wanted to make sure before i yet again put more stuff on a rogue that is not even mine....
Return to “Rogue Forum”
