Q451990 wrote:Are you sure the dimmer switch is connected, and if so - that it's not turned down? Also, I would re-check the connections to the hazard switch.
Heath
Skibane wrote:Are you sure the blinkers are dead - Or is it just the blinker dashboard indicator lights that are dead?
Hi guys, thanks for the reply. Sorry I haven't responded sooner, but my Q has literally been in suspended animation since the last time I posted. We've had about 4 major snowstorms in a row and I haven't even been able to get into my car, let alone try to figure this problem out, cuz the snow plows plowed me in really good. Anyway I finally was able to get back into it today and drive it for the first time in weeks.
First off, the headlights, fog lights, hi beams, tail lights, and brake lights are all working normally. However, my blinkers are
not working. They're not working inside and they're not working outside. I have no lights on my gauge cluster at all, with the exception of the parking brake and the tripometer lights. My radio DISPLAY is working except when i turn the headlights on, then they dim so low you can barely read the digits. The other radio lights for all the buttons are
not working. I still have the HVAC disconnected so i don't know if thats working or not. My entry lights are working and my dome lights are working. However, my automatic seat position and electronic tilt are both
not working
I have not yet reconnected the dash piece covering the gauge cluster which also has the clock attached to it. But that being disconnected wouldn't have caused this, would it?
Any other input would be great before I re-tackle this problem tomorrow.
Thanks
