HOLY CRAP MAN IT'S BAD REALLY BAD. that means that your fuel rail is leaking right into the damn block. I have solved both our problems. Pull your fuel rail then unhook the feed and fpr return line. Now with the rail in an area of the engine bay that you can see the bottom of the fuel injector in the rail you need to put back on the feed and return lines and apply fuel pressure. You will automatically see that there is an A$$ load of fuel pouring out of some of the injectors.
KEEP IN MIND DO THIS AT YOUR OWN RISK THIS IS A TRIAL PERIOD WITH THESE O-RINGS THAT I MATCHED UP. I hope that they stay in good condition and do not detiorate. I checked the specs on them and they seem fine.
I found some o-rings in the plumbing section of LOWES and guess what they work great. I replaced all 6 lower o-rings in the fuel rail and they held pressure and there is no leaking. Here is the info for the o-rings.
#83 o-ring and they came in a pack of 10 the lowes serial number is 198954 and only cost $1.27
Now i just ran the car and i need to tune it because it's back firing but i'm looking directly at the fuel pressure meter and it's a SOLID 38psi at idle and also i've seen it hold when i hit the throttle from inside of the engine bay at over 60psi. Tomorrow i'm gonna fix the timing and that should be it.
Keep in mind when installing the o-rings to use a heavy solid grease like vaseline or something of that nature and lube the bottom end of the fuel rail and the o-ring and they slide right in.
Now i know some people are going to have a problem with this but hey man i'm sure this should solve you problem. Your having the exact same problem that i'm having.
any other questions email me at
[email protected]/ yahoo mesenger sn is usmcgetsome i'll even give you my cell number to guide you along if needed.
