Tried to advance timing and ...
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
and car wanted to stall. what up with that??
CrimsonQ
Car: Purple People Eater
isnt your time advanced already with that ecu?
RobertsnewQ
How far did you advance it?
Did you adjust the IAC too?
jamesmost
RobertsnewQ wrote:How far did you advance it?
Rob my mechanic did it - tried to advance from 15 to 17.i asked the same and he did not touch the IAC.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
And which ECM are you running?
jamesmost
maxnix wrote:And which ECM are you running?
the same one i had on my origional engine. Quick chips program
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
jamesmost wrote:the same one i had on my origional engine. Quick chips program
And now for the $64K question, was it set to 17° BTDC?
jamesmost
maxnix wrote:And now for the $64K question, was it set to 17° BTDC?
Yes it was
CrimsonQ
well question answered:)
Q45tech
Setting base ignition advance requires the Consult [special screen to set]to lock out IAC and ECU from changing the number to try to maintain idle.
At the very least you disconnect IAC connection during the resetting process.
jamesmost
Q45tech wrote:Setting base ignition advance requires the Consult [special screen to set]to lock out IAC and ECU from changing the number to try to maintain idle.
I wonder why I was able to advance on my old engine (one thought - my idle was set very high at the time @1000)When I reconnect the IAC it wont jump back ??
