tried the ka forum but need a bigger audience i guess...
quinteros05
Car: 89 240sx hatch
My 89 240 auto trany shifts at 3000rpm every time and it kicks like hell every time until it gets to the higher gears. Any ideas? Pretty sure the kick is due to it coming off the low gears at a high rpm, I need some ideas on why its not shifting regularly. Ive heard it maybe due to a vacuum hose but they all seem fine, TCM need more info on that, or the tps... help!!!!
darens13
Car: '93 240sx, '90 chevy 1500, '49 dodge pickup
inhibitor switch maybe? i seem to remember seeing that in my fsm.
fun240
Car: 95' S14, 91' NX1600
Low fluid?
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
if you can't find the problem,
just replace the transmission with a used one, they can't be but maybe 100 bucks..
zerepdivad
Car: '90 240sx . '02 Lexus IS300
Did you see if you were throwing any transmission codes? When you start the car does your od light flash a few times?
quinteros05
Car: 89 240sx hatch
Yeah forgot to mention that the OD light flashes about 10 times when i start the car
quinteros05
Car: 89 240sx hatch
inhibitor switch... ill check that one out today and post what find..
zerepdivad
Does any particular flash stay on longer than others? if so which one?
quinteros05
Car: 89 240sx hatch
Sorry for the late response.... When it first comes up it stays on for about 5 seconds, then it blinks 16 times...
zerepdivad
Hmm according to alldata it should only flash like 10 times and if it's got an issue it will hold one of those 10 flashes for a bit longer than the rest......... 16 doesnt' sound right.
quinteros05
Car: 89 240sx hatch
ill go check it out again but counted it a couple of times... ill start the car this time, before i was just putting the switch on...
quinteros05
Car: 89 240sx hatch
yeap its 16..... and the first one stays on the longest...
Fibre guy
Car: 91' s13 RB25DET, 95' s14 bone stock, 87' Wrangler 4.6L stroker
Let's try how many miles does it have?KA auto transmissions are a dime a dozen because everyone wants manual.
whyteboi
Car: 1993 Nissan 240sx
mine is acting up somthing crazy, im just droppin the damn slush box for a 5 speed and call it done
ocalas240
Car: 1992 Nissan 240sx
i say just drop the stupid auto transmission and get a 5spd
quinteros05
Car: 89 240sx hatch
Yeah that's the direction it seems to be heading... What interests me is that it was fine, the car overheated on me and I had to change the HG, when I put it back together it started messing up. So i dont know if I plugged something in wrong or what... Ill prob end up going 5 spd just have to get the parts and set time aside to do it...
Oh yeah... it has about 190,000 miles on it....
Fibre guy
190 isn't the worst I've seen but there's no use beating a dead horse. 5 speed ftw!
ocalas240
im right around there aswell, if i had an auto id deff switch it out. make sure u get a nice clutch! i managed to break my crappy cheap one.
quinteros05
Car: 89 240sx hatch
Thank for the suggestions ... any suggestions in how to find all the parts in one sweep?? Also how well are the write ups on here for the swap? read over some but want to make sure they cover everything? Last question, after the swap does the tach and everything work properly or is there extra things that must be done ?? Thanks
