Died suddenly while highway cruising, towed home.
Sputters for a brief moment when cranking
I have fuel
Fuel pressure is 40PSI
Injectors are firing (testing done with test light)
I smell fuel after a bit of cranking
Good strong battery
I have spark on all 4
Using a spark tester, the spark will jump a good 1.25" gap
Brand new plugs, gapping is good
I have between 170-180PSI on all cylinders
Cylinder 1 at TDC and the cams are pointing outwards
The upper chain is taught, I cant access the lower chain
Under the distributor cap at TDC, the rotor has just passed #1 - seems normal to me?
I tried a few different positions for distributor timing and made no difference, then put it back to where it was.
Codes: 02 sensor post cat (normal), Fuel temperature sensor, Knock sensor circuit (could a faulty knock sensor cause a no start?)
I have fuel, spark, and compression. Any thoughts? It died suddenly with no warning, and will barely sputter now.
Thank you
