How do you get the fuel injector out of the fuel rail on a 1992 240SX? I removed the whole rail assembly so I can get to everything. I took the two screws out that hold the brack on top of the injector. I don't see anything else that holds it in but it will not come out. I used a large screwdriver to pry it out but it will not move. Also used wd40 to try and loosen it but no luck. I can rotate it but not pull it up. Is there a trick to it? I didn't want to break it and pull out the pieces.
Zoom45
