chaonis »
https://forums.nicoclub.com/chaonis-u45178.html
Mon Jan 05, 2009 8:03 am
90+% rubbing alcohol, a few Q-tips and a sponge socked with water.
Don't know if the rubbing alcohol will damage the paint but at least I use it all the time on my QX4 black paint and don't see any problems. I also wax mine all the time so maybe the wax is protecting the hard clear finish.
Just soak the Q-tip with alcohol and rub off the sap. then use sponge to wipe off the residues. One note: 71% rubbing alcohol you get from local supermarket has too much water and won't work as well. You really need something greater than 90%
