Warped »
https://forums.nicoclub.com/warped-u5976.html
Thu Mar 17, 2005 11:10 am
from the passanger side use a box wrench and use the closed end and slide your are right in there and walla i just took it out this morning and also 2 weeks ago so remember to pull the wrench up to loosen after you loosen enough you should be able to get your hand on it to remove it
