transmition
wanghoeby
Car: climbing paintball
I have a 95 standard all stock, no mods. Lately i have been accelerating quite briskly and have been redlining the first couple of gears. When i shift gears i can feel the trany vibrating quite a bit, through the shift knob. I am just curious is this bad for the trany/engine? Everything runs very smooth when i am just driving around town etc., . . . it feels so good to accelerate, but it feels so bad feeling the transmition vibrate so much.
thanks
MikeMurphy
Car: Guess
I dont have any inside knowledge here but maybe your driveshaft is bent?
NISTECH
mike is on it. check your drive shaft center support and your u-joints for play.
crazy2002mexican
Car: Racing, Paintball
i drive the same way and my shifter shakes alot but it doesnt feel like big vibration..could this be the same prob?
wanghoeby
i dont know all the things underneath are pretty sturdy. . . maybe its just that the knob is part of the driveshaft and the engine makes a good amount of vibration at 5500. . .
slakker
Car: Cars and Comps
Min also shakes in first gear and sometimes 2nd weird but doesnt feel everly bad though it does shake alot
wanghoeby
put it this way, should you be able to feel any vibrations through the shifter, or should it be smooth no matter what gear or rpm you are in/at?
NISTECH
no you will feel some vibration through your shifter that is normal. but it should by no means be harsh.
amvisrael
ok after i changed my clutch, a few days later my driveshaft gets bent and almost made a new air vent underneath my car. i got it replaced for a reman parts + labor for $300. but they only checked the driveshaft side. the shop is located 30 miles coz it was the nearest shop where my car got messed up and i dont want to drive all the way back there with paranoia of driveshaft breaking again. my shifter shakes like crazy 1st and 2nd gear i really feel a terrible vibration. im scared as f*** coz i dont want to spend $300 on another driveshaft. SO: new driveshaft + horrible vibration = wut do u guys think is wrong? i think it unbalanced so im thinking of putting new transmission mounts to atleast solve it. any thoughts?
NISTECH
unboly the drive shaft at the diff rotate it 180 degress with out rotating the diff and boly it back up.try driving it see if that helps your situation.
NISTECH
This is a diagnostic/drivability issue. I am moving it to the "online mechanic forum"
